- May 20, 2018
- 49
- Plaster
- Pentair Intellichlor IC-40
We have a new pool with about 25 ft of the 42 ft length on one side as an infinity edge. Drop is 4 ft to the catch basin. We love the look, still trying to find best setup of drains, returns, skimmers.
The main pool has two skimmers opposite the infinity edge, two main drains in deep end, three normal return jets and twwo 18" spills - one on each side of the infinity edge. The catch pool has a single center skimmer and 4 main drains. This is all operated by a single intelliflo VS pump.
The builder left the valves set so the main pool drains are off, main pool skimmers do very little, and essentially all water goes over the edge for the waterfall effect. Catch pool is probably 90% main drains, 10% skimmers.
With everything going over the edge the skimming effect of the upper pool is obviously very good. However, I think there is a little cloudiness in the main pool because it isn't being filtered well. With a single pump, I don't think I can open main pool drains and use the infinity edge at the same time. If I do, and that valve is partially between the two drains (upper and lower), hydrostatic pressure forces water from upper pool through the valve into the catch pool, which then overflows.
I can turn the lower catch pool drain system off, shutting off the infinity edge, to filter the upper pool. But, at least at the moment that is a manual process.
Any thoughts or suggestions on how to best manage this setup? I've thought about paying for an electric jandy valve to swap to filter main pool at night, but I think I'd have to upgrade the controller to handle another zone. Not sure what else I could try.
