Good Evening,
I'm having a hard time with my water for my indoor 10k gal pool. Not a lot of resources out there. My water seems to have lost its mind !! I have well-water.
TA100 - PH 7.2 - TC - 0 - I don't use a lot of stabilizer as I don't really need it being indoors - and that is usually the last thing I add.
I dumped 2 gal of chlorine in - turned the water yellow for a week (calculation would say that amount of Chlorine should have jumped the pool to 24 ppm). I scrubbed, vacuumed, and back-flushed until the water turned clear. Tested the Chlorine - no reading
but the TA jumped to 140 and PH to over 8. No sunlight or rain to affect the TC.
Can the Calcium hardness be using up the Chlorine ?
Could there be some sort of metal reacting with the chlorine ?
I do not have the CH or metal test kit
One other odd situation is the color of my Chlorine, PH, and TA tests
Chlorine turns orange, PH varies from vivid purple to vivid orange (not the pastel colors on the test kit), and the TA goes from purple to clear yellow instead of clear. Could my reagents be too old ? Would something else cause the tests to come out like this ?
I'm guessing Calcium Hardness due to the scale I had to clean out of my heat exchanger.
