I'm having trouble getting consistent chlorine results.
I'm in the SLAM process.
In 4 consecutive tests this am these are the results:
20.5
15.5
14.5
22.0 (5ml sample)
All tests were using the same "master sample" within minutes of each other.
All test supplies are current....not old or outdated
The only thing I can figure is the amount of powder used??? however I try to be consistent within reason.
I'm confused
FC: see above
CC: .7
Ph: 7.5
TA: 110
CH: 425
CYA: 55
Salt: 3400
Temp: 84
With the exception of chlorine these test results were prior to start of slam.
20.5
15.5
14.5
22.0 (5ml sample)
I'm confused
FC: see above
CC: .7
Ph: 7.5
TA: 110
CH: 425
CYA: 55
Salt: 3400
Temp: 84
