Hello! San Antonio new build. Pool has been leaking since they built it. A return was cut short which created a huge leak in the yard. Pool was filled in May and leak wasn’t fixed until a month later.
After it was fixed the ground under the concrete decking was still damp.
They just emptied the spa on Friday to see if the area would dry up and it appeared the wet area initially got bigger.
Any idea why that would happen? Pressure tests shows no big leak. There is definitely still a small leak somewhere. We have lived in our house 7.5 years and our yard was never wet.
Pink denotes calcium deposit on tile that constantly is there even after acid wash.
Red denotes return that was leaking 360degrees from pipe being cut short.
Blue denotes several sections of Concrete behind and both sides of spa have already cracked. Poured in January.
Pool was started in Oct 2020 and sprinkler system has been off since day 1 of dig.
Any help would be greatly appreciated. The pool company will not acknowledge it could be their work.
Thank you in advance,
Kathy
Kathy
