Impressions and long streaks in our StoneScapes plaster.
DanielHobley
Active member
Apr 19, 2019
36
Houston, TX
Hi there,
Our pool was built last summer and filled in July. Shortly after everything was up and running (and the family was swimming), I noticed a few impressions (like the white spot next to the pool vacuum; there are several and you can press your fingertip into them) and streaks. The builder did not have much to say about the impressions and suggested we shouldn't expect a completely smooth surface (and was silent about the rectangular impression altogether). After their plaster guy came out to look at everything, we were told to brush (brush, brush, and brush) to help get the streaks out. It's now January and nothing has changed. I've reached out to the builder again, and I'm expecting their plaster guy to stop by sometime in the next few days. Any thoughts or insight I should have in preparation for their visit? I feel like we were brushed off last time (pun intended).
BTW, the pictures aren't the greatest. You really notice the streaks when it's overcast, and we discovered the impressions while wearing goggles and running our fingers along the bottom.
Thanks!
Brushing is not going to remove the streaks. Neither will any changes in water chemistry. Pool builders have to tell you something and then they make you feel it is your fault as you did not do it good enough.
They are all variations due to the manual nature of plastering. Every job is unique and few are perfect.
Understood, and thank you for the informative links. A bit disappointing as far as the builder goes, but not unexpected.
