I know that SWGs should be turned off when adding salt, especially large quantities of salt. The pump should also be run 24 hours straight. Is there a major risk to adding up to 40# to 13K gallons in a plastered pool, leaving the SWG system on and perhaps leaving the pump schedule run as usual? Salt would be brushed-into the shallow end.
Sometimes while I'm away from home for an extended period the pool gets diluted to near the minimum salt level and having someone make multiple trips to the house just to add some salt is an imposition I'd rather avoid if possible.
