In this order.
1.The shaft seal is not in correctly, or flush (tight enough) or wrong size.
2.The impellar threads that thread on to the shaft are cross threaded or damaged. Some are plastic, and some are brass.
3.The diffuser is not mounted tight enough, or missing a screw. Or sometimes once in awhile its mounted and tightened down to tight.
4.The seal plate rivets where the diffuers screws go into are warped, damaged, rusted, and the diffuser screws seems to screw in tight but are not really screwed in at all. Rather jammed in.
5.The seal plate is not mounted tight enough to the motor. losen the bolts a little and tap the seal plate with a hammer while re tightening to bolts.
The motor shaft being bent is a unicorn, and probably worth money if you find one.
