I just finished another summer season during which I had to work very hard to keep my pool clean with the algae at check.
Despite keeping proper FC and Ph levels I needed to slam the pool too often (every couple of weeks if not more often) and to scrub almost weekly to keep the pool algae free.
If you take at face value my comment around proper maintenance, could the cause of my trouble be the fact that the Iroko hard wood that goes around my pool is also used as skirting which is submerged into the water?? (by around 1 inch).
My theory is that once the wood is infected by algae shocking with chlorine and scrubbing are not enough to completely eliminate algae, which is the reason why algae appears first on the hard wood and if left alone start to appear on the pool walls.
Any thoughts?
Any effective solutions other than removing the hard wood skirting?
Any thoughts?
