Different problem, but continuing from:
Problem: I'm getting very different FC and CC readings - even from the same sample.
My readings from most recent sample:
TA - 40
pH - 7.8
To get multiple tests I used both my TF-100 tube and the DFD 2006-k Tube for a chlorine reading using the same water sample. (Same Powder, same 0871, same 003 - just different tubes)
Both tubes came back with different FC/CC readings?
The TF-100 tube had FC - 4.5 and CC of .5
the DFD tube had FC - 1 and CC of 4
This water sample came after aerating 5 minutes so I could get a good TA/pH reading.
What should I do?
Thanks for the help.
Hot Tub Start Up Questions
Problem: Keeping my TA at 50 causes pH to raise to over 8+. pH was only in 7.6 range when my TA was LOW(20 ppm). I'm following the "How do I use Chlorine in my Spa" instructions for the first time(I was using frog ease prior). This is after a drain, scrub the tub, and refill with my hose...
www.troublefreepool.com
TA - 40
pH - 7.8
What should I do?
