- May 23, 2015
- 25,697
- Plaster
- Pentair Intellichlor IC-60
Once they are finished you will need to re-balance the pool. RO is great for getting rid of excess calcium and CYA, but it is not offered in enough locations for it to be a replacement for drain and refill in most cases. In an area with inexpensive water and no use restrictions a drain and refill will be quicker and more cost effective.
I have heard that RO companies will not process algae filled water. Do you know if this is true of the company you are working with as well?
Yeah, Tucson Water just started adding a tiered charge system for the "service charge" portion of the bill. The usage rate was always tiered but the service charge was static - you paid $20 per month for your account whether you used water or not. Now they have both the flat service fee AND an additional service fee based on a tiered rate for water consumption. It's totally ridiculous and adds a lot to the monthly bill. So previously drain and fill was right on par with RO but now it would be a lot more expensive to drain and fill.
As for algae I would believe it because the pre filter sediment traps will clog up like crazy. If/when I do RO, I'll schedule it for the fall after the water temps drop and algae is less of a danger.
