Worth pointing out the salt test portion can be bought separately later as needed. You don't need to replace the entire kit.
I called TFTestKits directly and they recommended the TF100 Pro and do the salt water add on next year as the cost is essentially the same but I won't have the reagents sitting around for a year that I don't currently need. Spoke with Nate, excellent customer service and very knowledgeable!
@Leebo How would this poster check for bacqua product in their pool? The previous owner seemed to mix and match chlorine & bacqua products- The Sanitizer/Algaecide in particular?
Most of the other products could be purchased cheaper, or not at all effective.
The TF100 Pro will be in on/about Friday this week. This actually works pretty good for me because I am on well water and just had to waste nearly 1.5ft deep of my 20'x40' pool to get the stuff that built up on the floor of the pool out. It's crazy because what I vacuumed up was almost scales like paint chips in a way. The kit coming in Friday will give me time to build my water levels back up without fully draining my well.
In the meantime I am wondering if I should just be shocking the heck out of it? My pool store CYA reading was 5 and it seems no matter what I throw in it by the morning it's just gone. Reading up on CYA it seems imperative to have this at a proper level or else anything I am doing is essentially just throwing money in a fire pit. Attached is the results from the pool store on 5/28
Mind you, they told me just to add 15lbs of shock, 5 lbs of Alkalinity and do that again in 2 days. Learning about CYA I see why I am putting $60-$80 of shock in every 2-3 days.
