I intend to install a high quality, accurate pressure gauge this season. Research led me to Ashcroft, a manufacturer of industrial gauges.
www.ashcroft.com
As luck would have it, the territory sales manager is a fellow pool lover. He provided these two pearls of wisdom related to gauges and pools.
- Dry gauges avoid temperature issues associated with liquid filled gauges.
- Consider a range that keeps the pointer as close to the 12-o’clock position as possible when filter is operating
At his suggestion, I purchased the Ashcroft 1009 Duralife Pressure Gauge, Part Number: 25-1009-SW-02L-XLL-30#
- Industrial grade
- Accuracy: 1%
- PLUS! dampening system for vibration/pulsation (liquid-filled performance in a dry gauge)
- 316L Stainless Steel case
- Range 0-30 psi
Link to 1009 Data Sheet
Attached is a photo of the Ashcroft 1099 gauge. Also attached is a photo of the internal workings of the Pentair OEM gauge, which I was
compelled to pull apart to satisfy my curiosity.
Ashcroft gauge and box
Inside and face of Pentair OEM gauge
