Im at a loss.......?
I’m jealous!! Going into day #8 of my SLAM. Hope it ends soon, cost of bleach is starting to add up. My OCLT keeps failing, losing about 4ppm each night. :brickwall:
Make sure that you are raising your FC high enough for your CYA. If your OCLT is not improving with time then you may not be adding enough chlorine for the SLAM. If the water is getting cleaner then you will see the OCLT losing a little less FC with each test or at least after a few days into the SLAM.
Mike.
