If I just installed a Pentair C & C Plus and then vacuumed DE off the floor will the cartridges need to be cleaned now?
DE cartridge elements are a a woven cloth designed to accept DE, and to allow DE to wash off of it.
Non-DE Cartridge elements are a non-woven material that the DE can wedge itself into and be VERY hard to clean off. We generally don't recommend it as it will permanently clog your cartridge filter and cause higher pressure drop long term (until you replace the cartridge).
You did it. It is done.
Now open up your filter and give the cartridge a good cleaning before the DE gets any more embedded in the filter.
What was your clean filter pressure when you started up the new filter?
What is the PSI now?
See what the PSI is after cleaning.
Reactions: proavia
Did you switch or is this theoretical ?
If theoretical, (debating the upcoming switch) keep the backwash leg with a 3 way diverter between the pump and filter for vac to waste. Then sweep the DE to a general area (gently, will take a few tries with breaks allowing it to settle). Then vac to waste.
Product Description
The Filter Fiber Stuff combines high performance, outstanding value, and environmentally friendly features into one great product.
When used as a safe alternative to DE in DE filters, The Filter Fiber Stuff requires less than half the amount of product (by weight) than needed when using DE.
It can be used to enhance the filtering performance of sand and cartridge filters as well.
The Filter Fiber Stuff is non-toxic, making it safe to handle and store. It can also be backwashed safely as it is biodegradable.
The Filter Fiber Stuff extends filter runs, reduces filter clogging, and results in sparkling clear water of the highest quality.
Can the Filter Fiber Stuff be used as a DE filter replacement?
Yes it can.
Is the Filter Fiber Stuff safe for use with sand/ cartridge/ DE filters?
Yes, the Filter Fiber Stuff will increase filter efficiency in all kinds of swimming pool filters.
Do I need to disassemble my filter to add the Filter Fiber?
No, the Filter Fiber stuff is simply added through the skimmer.
How should I backwash the Filter Fiber Stuff?
Please backwash and/or dispose of the Filter Fiber Stuff in accordance with your local or state regulations.
Product Dosage
DE Filters: 1 DE scoop of fiber per 12 square feet of filter area
Cartridge Filters: 3 ounces (by weight) per 25 square feet of filter area.
Sand Filters: add 3 ounces (by weight) at a time, with a maximum addition of 9 ounces (by weight).
All of our content is free of advertisements.
Please consider donating at:
The PSI has been 10 since it was installed and has not budged. Supposedly the PSI on filters with 4 cartridges does not increase as much, if at all, as in DE filters and cannot be used as a barometer of when a cleaning is necessary. Though, I also have a pre-filter installed.
Where is that said???
Link to forum post on Reddit
What barometer will you be using?
NOTE
For first time operation on new pools introduce into the system .75 pounds of diatomaceous earth per every
100 square feet of filter area (a one-pound coffee can equals .5 pounds of diatomaceous earth).
Mix the diatomite with water and pour it into the skimmer after the pump is primed and the system is operating. This will enhance the filtration of your water
  • Filter-PentairClean_ClearPlus.pdf
When the cartridge element filter is used on new pools and after cleaning the elements, introduce into the system .5 pounds
of diatomaceous earth per every 100 square feet of filter area, (a one-pound coffee can equals .5 pounds of diatomaceous
earth).
This will enhance the filtration of your water.
  • cleanclearmanual.pdf
NOTE
Yup, that is an older Rev M manual from 2012.
It seems someone at Pentair changed their mind about recommending adding DE.
I think the point we are making is that there may be some carts that can handle it and some that don't. The DE carts are woven and will handle it.
We've seen too many issues adding DE to a cart filter, and no way to know that your carts can handle it, unless they are DE carts.
We are recommending that you not add DE to a non DE cart.
Jamesw'd
Reactions: JamesW
