I’ve been trying to figure out, with little to no insight from the manual, how the on and off cycle of the ichlor30 works. Or any SWG with a selectable output for that matter. Obviously the output percentage indicates how much of the run time the cell is actually on vs in standby mode, but how does this actually work and in what increments? For example... if I run it at 100% for 12 hours it will output .5 lb chlorine and be “producing” for all of those 12 hours. If I run it at 50% for the same 12 hours, I should get .25 lb chlorine generated, but now the cell is cycling on and off to output 50%. My question is this, given the last scenario, 50% for 12 hours, the cell is only producing for 6 of those 12 hours... does it cycle in .5 hr increments, 1 hr increments, 3 hr increments, 15 min increments??? The purpose of knowing this is to be able to reduce the output by a calculated amount by turning off to drop my FC as needed then power back on to the last setting which maintained my level after full sun and moderate bather load every day. Anyone have insight?
