- Apr 21, 2020
- 1,323
- Fiberglass
- Pentair iChlor 30
I was on vacation the last two weeks. I did my latest tests today. Everything looked good except FC has dropped from 11 ppm to 5 ppm. A drop was expected since I lowered the output from 45% to 30%. I'm still trying to dial in the SWG for this time of year. When I checked the iChlor 30 display, I had a solid red LED for the salt level. In the manual, this indicates a low salt level between 2600 and 3000 ppm. On the status LEDs, the cell LED is solid green which means cell is operating normally. The flow LED is solid green which means the flow is sufficient. My salt test result using Taylor's K-1766 kit was 3400 ppm which is the same result since April 24. The LED was not red during my previous two results of 3400 ppm.
Is this an indication that something is wrong with the cell? Since the optimal salt concentration is 3600 ppm, should the first step be to add some salt to bump the level up to 3600 ppm to see if I can make the cell happy?
