Hello all. I just had an in-ground 20x40 vinyl liner pool installed this past summer in upstate NY. It has a conventional skimmer / return plumbing system, with a cantilevered poured concrete deck. It also has a Merlin Dura-Mesh safety cover installed. The pool was closed by the pool company in mid-October 2018, and water level at closing was about 1" below the skimmers. All lines were blown, antifreeze added, and gizmos added to the two skimmers. I have not checked water levels since closing, and this is the main reason for my post.
I noticed about 1-2" of ice on the top of the cover, and went to investigate. After realizing the ice on the cover was being supported by the ice in the pool itself, I checked the skimmers. Currently, the ice in the skimmers is 3.25" from the top of the skimmer, meaning we had at least 6-7" of water added to the pool since closing via rain / snow melt. I called the pool company, and they told me "checking water levels is in the manual we gave you". Well yes, it was. And I also asked the pool guys about draining water when the pool was closed, and they said since it was so late, I probably didn't need to worry about it.
So now I'm having terrifying visions of a destroyed pool come spring. Could the ice build up sufficiently to lift the cantilevered concrete? Could the skimmers be destroyed? What other kind of damage could I be looking at?
Also, is there anything I can do to mitigate damage? I'm thinking that trying to keep as much snow off the cover over the remaining winter months would be prudent. Anything else?
Or am I over-reacting to this as a first time pool owner, and what I'm seeing is completely normal for Upstate NY?
Thanks for an and all insight,
- pc
- pc
