- Jun 18, 2019
- 354
- Plaster
- Pentair Intellichlor IC-60
Thanks to this forum, I think I discovered my salt sensor/flow switch is broken. IC60 was installed this April. I tested using K1766 and it was 19 drops (3800 ppm) and the salt cell reports it's operating, I can send controls down to it (new levels), and it appears to be producing chlorine, at least it has been up until now. I'm not sure the last time I looked at the app, but I'm certain it was working a week ago.
Anyways, here's my question as I read things about no salt level versus bogus salt levels. While testing chlorine this morning, I went into the app to bump up my cell by 5% as I was 0.5 - 1 ppm below my target. I noticed my salt read 2350 which I knew was way off. For peace of mind I did the K1766 test. Then I cycle the pool mode on and off. From then on, it reported no reading (--). I rebooted IntelliCenter, and then did the "Hold Down MORE for 5 seconds" procedure I found on another thread. The cold water LED lit up red which I think based on the description indicates a bad salt sensor.
I know this is not the sensor the IC uses to actually function and is just for reporting. My PB said he'd file a Pentair claim and they'd be calling me. Might as well get it fixed for free, but I'm just curious what the bogus reading prior to the whole think pooping the bed would indicate? Is it possible it could be more than the sensor?
