It does not dose when the salt is low, but I do not understand why the salinity matters.
Take the IntellipH out of series with the cell and power center until you can get the low salinity issue fixed.
Power the cell directly from the power center and run the cell and IntellipH independently.
XXXX DIDN’T DOSE: The number of doses not dispensed due to the following conditions:
• Low Water Temp. (< 52° F)
• No Flow
• No Communications
• Low Salt
• Clean Cell.
IntellipH Controller Installation
The IntellipH Controller is installed “in series” with the IntelliChlor SCG.
The IntelliChlor SCG cell cord plugs into the IntellipH Controller and the IntellipHController plugs into the IntelliChlor Power Center, EasyTouch or IntelliTouch Control Systems Load Center power connector.
To install the IntellipH Controller:
1. Choose a location on a wall or vertical surface near the IntelliChlor SCG power center (P/N 520556) and/or the EasyTouch and IntelliTouch Control System Load Center.
Secure the IntellipH Controller to the surface with the three screws.
2. WARNING! SWITCH OFF or REMOVE POWER to the IntelliChlor SCG.3.
Remove the IntelliChlor SCG cell cord from the power center, EasyTouch or IntelliTouch Control System Load Center.
Insert the IntelliChlor SCG cell cord plug into the bottom of the IntellipH Controller.
4. Plug the IntellipH Controller cord into the IntelliChlor SCG Power Center, IntelliTouch or EasyTouch Control System load center where the IntelliChlor SCG cell originally was plugged in.
