SO I checked out my installation and the pump, SWCG, and my UV light are wired to our timer clock, which has those pins you screw on for turning it off and on. We do not use that, because as previously stated, the pump needs continuous power (I also read that in the manual). I noticed this morning when checking FC that the UV light was on, which the user manual states, should only be on when the pump is on (flow). SMH. My builder is aware. I do not think the SWCG and UV light are wired wrong, I believe the pump should not be on the same circuit as the other equipment as it needs power all the time and it has it's on timer and clock.
