- May 12, 2020
- 82
- Vinyl
- Pentair Intellichlor IC-40
A couple of weeks ago I found my IC40 not working and tracked it down to a blown fuse in the IC40 power center.
Finally got around to replacing the fuse this weekend, and when I threw the breaker for the power center it immediately had smoke coming out of the port for the cable that goes to the salt cell. Thankfully I had disconnected the cable when I was troubleshooting why the power was out.
You can see in the bottom of the picture where the wires look like they got fried so I'm guessing the surge board is also fried, although the green light was on the whole time there was power going to the power center, and the fuse did not blow.
I'm guessing the power center is about 10-12 years old. Am I ok to just replace the surge card with this one - Pentair Kit Surge Board PC100 521034Z? Or would I be better off replacing the entire power center? I'm not sure what the life expectancy is for the power center, although I would guess that the life of the transformer is longer than 10 years.
I appreciate any suggestions and advice any has.
