- Mar 20, 2021
- 7
- Vinyl
- Pentair Intellichlor IC-40
Hello all,
I am in the process of converting to a SWG and am at the wiring stage of the IC40+PC100. I'm scratching my head a bit wondering if I'm missing something obvious with the wiring.
Here's what I have:
Here's what happens (no IC40 hookup yet--only the PC100 is connected):
Pictures and a poor hand-drawn diagram are attached. I am typically pretty good at simple electrical circuits, but this one has me scratching my head. Am I overlooking something simple?
Thank you for any help/guidance!
Here's what I have:
- 120V at the pool subpanel
- Single pole switch controls my pump, so I am tying the PC100 into that
- At the switch, I added a pigtail for hot and tied the neutrals + grounds together
- At the PC100, I followed the diagram and tied yellow+black to hot and white+violet to neutral
- Upon first fire up yesterday, the transformer was humming loudly and within a minute fried the internal 10A fuse and then tripped the breaker
- I replaced the fuse, left the cover open (to try to get some live multi/clamp readings), and it trips the breaker immediately now before it has a chance to fry the fuse
- I disconnected the PC100 so only the pump was connected, and it runs fine without issue for extended periods. It ran fine while the PC100 fried the fuse yesterday, too. This leads me to believe the issue is with the wiring at the PC100.
