Couple of questions. I’m installing an IC40 with the iAqualink system. Is there any way these two will communicate with each other to where I can control it with my app? Or will I be running the IC40 independantly?
Second, question on wiring... I’m running a Pentair Intelliflo pump with my iAqualink, how would I wire the salt transformer into this setup? There is a flow sensor built into the IC40 already, correct? Do I simply wire in the 220v into a new GFI breaker or through one of the relays?
Attached is a picture of my set up. The wires highlighted in green are the pump wires to the upper left relay.
Many thanks in advance
