- Jun 4, 2007
- 242
- Fiberglass
- Pentair Intellichlor IC-40
Hi, all. My pool is sloooowwwly getting finished. One issue is that my newly independent pool guys understand construction and wiring but don't really understand EasyTouch programming, so nothing automatic is set yet and it's still on Service mode and ScreenLogic is still off. They supposedly have "a guy" who's going to come out and work on that but he's being difficulty to schedule. I may figure it out before them....
They didn't have any CYA in the pool, so I fixed that, but because they had the SWG dialed up so high I was about about 25 FC. I tried to set the IC40 via the panel at 5%. The EashTouch panel shows that's the setting but the lights on the IC40 itself show it's generating at 20% (two solid green lights). Anyone have any idea what gives? I turned it down before when he had it on super boost and it worked. Adjusting the pump speed via the panel seems to work, the display on the pump matches what I set on the panel.
