I have been running and easy touch with an IC40 and a basic Sta-Rite single speed pump. I have both the the IC40 transformer and the Sta-Rite connected to Filter relay. When the filter relay is turned on, both the pump and IC40 power up. When it is turned off, they both turn off. It has worked great.
I am going to install the Intelliflo today and I understand that you want constant power to it. So I will connect directly to circuit breaker and then connect the com cable to the com port.
1. The screenlogic is already in the com port. I assume I just put both the screenlogic and the intelliflo com cable into the same port. Can someone please confirm?
2. How should the IC40 be connected moving forward? Do I just put in the same circuit and allow the flow switch to determine on/off? I Assume it would not be right to leave it in the relay so it gets switched by the relay when the pump won't be. Can someone please confirm?
Thanks
Thanks
