- May 16, 2011
- 1,182
- Plaster
- Pentair Intellichlor IC-60
My Pentair IC-60 has suddenly stopped working. It was working yesterday, but now there are basically no lights, except for an intermittent blip of the red light by the “Low” reading.
I bought the cell in June of 2022 to have “just in case” and installed it March 14, 2023 so it really shouldn’t be having issues at this point.
Leading up to this, as my water temperatures have been dropping, (current water temperature is 73) the salt reading was going abnormally high. It currently reads 9000 when I have tested it to be 3400.
I turned off all my circuit breakers and let the system rest for a few minutes. Then I detached and reconnected the cable to the control box. These did nothing. Finally, I slid back the plastic cover to the salt cell and accidentally popped off the whole thing to reveal the electronic insides. I didn’t realize this came off, but I found water inside and wonder if this is the problem? It’s hard to tell from the photo, but there were puddles in the corners, and everything is shiny is because it’s wet.
Do you have any thoughts on what I should do next to get this up and running again? Thank you for your help!
