- Dec 25, 2021
- 91
- Plaster
- Pentair Intellichlor IC-40
Howdy
I had my IC40 replaced under warranty. Yay! Last year I had the output set to 20% and that kept my FC levels pretty darn good. Occasionally had to add liquid chlorine and acid.
Regardless this season with the ‘new’ ic40 things aren’t going well. 20% isn’t keeping up at all.
Any thoughts on how to diagnose the IC and prove it’s working? I turned it up to 50% as of now fyi. I have a heater running on hood weather days. I also keep the pump running constantly. My levels are as follows:
Ph 7.4
TA 90
cH 550
Cya 35
Salt 3050
Temp is 90
I added a few pounds of stabilizer to increase my CYA maybe 2 weeks ago. It didn’t change. I used a powder stabilizer…I think a Clorox pool powder. Maybe a tab will increase the CYA and allow the chlorine to stabilize? I did find it strange that my cya fell from last year. I was under the impression that cya only rises unless you remove/replace water and normal evaporation wouldn’t change that level.
Tell me how wrong I am please and thank you.
Ph 7.4
TA 90
cH 550
Cya 35
Salt 3050
Temp is 90
