I've had good luck with this device, but I recently found the antenna split open. The connection has become a bit less reliable and I want to replace it, as the internals and the box are fine.
The pool is at a different location than I currently am, and so I would love to get a photo of the antenna and the connection used to connect the antenna to the board, and I also need to know the frequency spec of the antenna so I can find a suitable replacement wither from Jandy or elsewhere.
Any help appreciated!
