- Jun 24, 2021
- 8,103
- Vinyl
- CircuPool RJ-60
I will try but I'm sure our town utility place will laugh or I don't know. Either way, I have a plan in place it really isn't that big of a dealI will repeat what was suggested earlier: call your local wastewater facility. That's how I located my cleanout under some bushes after weeks of fruitless searching. They emailed me a diagram and done!
No dice on utilities but I still have a solid plan for tomorrow. In prep for partial drain & fixing plumbing. I tested our fill water. I've done this before and it always baffles me based on this I should be ok after refilling for a little bit at least.
Lol I don't peopleJust a thought for finding the cleanout. If you live in a community with the same models for the homes. In many cases, there will be a mirror model, garage on the right side and the mirror with the garage on left. You might have a neighbor with your exact model and if they are neighborly you could see where their cleanout is. Yours should be in the same place. Again, just a thought.
We haven't, we peek around every 15 min but it has the same consistent flow & drain working well. The hose is being held by the window lolI would not walk away from that sink for too long. If that drain ever stopped or that hose gets loose from the sink, that room will flood in no time.
Just my normal Home depot down the street lolAt least you know what to do! Do you have good, easy source for liquid chlorine?
