So short version, i got a leak in some plumbing from filter to pvc, I ordered a new piece, it took a week to get here, I turned the timer/pump/swg off with my cutoff switch. When I got everything replaced, went to turn it on to test and nothing turns on. If I keep rotating the timer over and over, sometimes the lights on the VS Superflow pump will flash for a second. I dont think I even need the timer, since I have VS Superflow which has it's own schedule but no freeze protection. I dont know if somehow I broke both the SWG and the pump, but honestly not sure how to even wire everything together if I remove the timer to even check either device. I had an electrician come out and they said its getting power to the timer, but that's all he really checked. Thoughts? Is there some way I can just remove the timer out of the question? Or do I really just need to get a new timer? and is it possible it's not the timer? I took the panel out of the case and looked at the back and I dont see anything unusual. The black cable coming out of the bottom goes to my circupool SJ45. I have a Pentair SuperFlo VS Variable Speed Pool Pump 1.5 HP 115/208-230v.
