- Jul 21, 2013
- 54,292
- Plaster
- Pentair Intellichlor IC-60
I would not use WEF to compare pump efficiencies. It will lead to the wrong conclusion. Because of the way WEF is defined, larger pumps always have lower WEF even though they are more efficient at the same flow rate. It is nearly always advantageous to go with a larger THP VS pump for both noise and efficiency.
Note on WEF pump ratings
I just updated the Hydraulics 101 sticky with the following paragraph as WEF seems to be getting some attention. Any feedback is welcome. --------------------------------------------------------------------------------- Pump WEF Rating DOE has adopted a metric for rating pumps for their...www.troublefreepool.com
Yup, that is the conclusion I came to in post #18.
