50 ppm Borates added to water at a pH of 7.5 will only raise the TA by 5 ppm. At a pH of 7.8, it raises the TA by 10 ppm. Since that rise is not from carbonates, you don't need to worry about that higher TA level since it does not result in any increase in carbon dioxide outgassing. I'm not sure why you saw it rise by 20 instead of 10 -- might be slight test error (on the edge between drops) or maybe you measured the TA before borates at pH 7.5 and after borates at pH 7.8 which would be another 7 ppm TA just from pH adjustment with a base (e.g. borax). If I were you, I'd see the rate of your pH rise currently. If it's fairly stable, add the rest of the borates. If it tends to rise, then you can do the lowering TA procedure before adding the rest of the borates (if you want -- not essential, but would help reduce the rate of pH rise).
