I have never gotten a handle on balancing my salt water pool... ph issues/ scaling etc.
Texgirl
244
I love my salt water pool... but the ph creep constantly has been so difficult to manage... had my pool since 2013.. i know we let it creep up too high. I feel like I need to add acid every few days to keep in check... what can we do to better maintain and get out of this constant ph of 8 or higher that we can never seem to get control of.....
ajw22
16,042
Northern NJ
What is your TA?
What type of pool? Please create your signature with details of your pool.
Needing to lower pH every few days is a fact of pool owners. Some folks install automated acid dispensers. They have their pros and cons and need watching over and periodic maintenance.
Texgirl
244
What is your TA?
I think I created my signature... thanks so much. I have thought of the automatic dispenser!! I just get busy and forget to check it... I have read about borates to help stabilize the ph in salt pools.. Looking for thoughts on those sorts of products.
ajw22
16,042
Northern NJ
After you give us a complete set of current test results we can discuss what you need to do and the use of acid dispensers.
Texgirl
244
Ph yesterday was 8.0 ... added acid, today it was 7.6. TA 50 CH 450 , tc 3, cc 0
I am thinking about getting a water guru... help me stay on top of things better. I wonder if it has alerts.. like ph is 7.8 alert or something!
ajw22
16,042
Northern NJ
What is the pH and TA of your fill water?
You have an autofill on your pool?
You running any spa overflow or water features regularly?
Texgirl
244
I will need to test my tap water.. no autofill, yes spa overflow on regularly when pump running but no other features are on.
ajw22
16,042
Northern NJ
Your spa overflow running when your pump is running is contributing to your pH rise. What is your daily pump runtime.
Do you have automation that can run your spa spillover for 15 minutes twice a day?
Texgirl
244
I have automation.... but when the pool is on it overflows.... I don't think I am able to not have it spill over....or if I am somehow I don't know how....
ajw22
16,042
Northern NJ
Post pics of your pool equipment pad and valves. Especially around your return line.
Your signature does not show any automation. Many automation systems have a spa spillover function. What automation do you have?
Texgirl
244
corrected my signature! I have hayward pro logic 4. I will take a pic tomorrow. thanks so much!
Texgirl
244
I have water guru, it definitely helped to keep on top of my pH on a daily basis.
awesome! Tell me about it!! It seems like it would really help me... were you having scaling issues etc? If so, did it help you get a handle on things better? Thanks so much, KIM
dorgan
175
Rockledge, FL
Yes the water guru really does help. Brought in a local pool guy to help brush and treat for the next couple months, as well as look at treatment options. Worse comes to worse we'll do an acid bath.
