I have a Coleman 22x52 that is probably beginning it's last season. I have a 16" Hayward sand filter connected to a brand new 1hp Hayward pump that has the original hoses attached. Those hoses have developed cracks that allow for AWESOME sprays of water that are very frustrating for me. I have no problem replacing those original hoses... that's easy enough. The problem I have is with my plunger valve. The original valve that came with the Coleman pool apparently had a shallower depth to it, since when I've tried to connect my Intex plunger valve, that I purchased to replace the Coleman, I've found it won't tighten up. It's just all loosey-goosey... and that is not good. I considered trying to find some washers that would take up the difference in space, or maybe I need to buy a new eyeball that leaves more thread space for the plunger to hook onto? I tried to figure this out using my little brain, and so far, it's pool 1,000,000... and me zero. Has anyone else run into this? Maybe you can be my new best friend.
In the pictures you can see the eyeball connection. I think that was replaced a season or two back, but I cannot recall for certain. Then we have the original valve, which I broke as I was removing it, and finally the new Intex plunger valve, that will not thread on tightly.
