My new SuperFlo is installed and pumping. The default operation is a priming mode upon startup - it revs-up to a full 3450 RPM for 5 minutes. Wow is this sucker loud! 87 db at full speed compared to 78 db of the old one. I can hear it throughout the house. I suffered a few "what have I DONE" moments before the priming cycle ended. I cycled through the default speeds, which are 3000, 2200 and 1400 RPM, and then played around adjusting it at 10 RPM increments. At 2200, the sound level is the same or maybe less than the old pump. (I'll measure it tonight when I program a schedule) At 1400, it can't be heard outside of the pump room. Naturally, the energy consumption is a fraction at that speed. My pool has good circulation anyway, so I'm expecting big energy savings. I'm also looking forward to less circulation while swimming. At 3,450, all the pool toys and floats gather at the skimmer within minutes!
It struck me that the only speed of the old pump seems crazy on the new one. "Why would I ever run the pump that fast?" I'll experiment with the different speeds while vacuuming, but my gut tells me that I'll prefer 3,000 or less to 3,450. The vacuum head can be hard to control when there's a lot of suction, particularly in the deep end.
My plumbing is oriented in a way that puts the pump basket in front, which means the control panel faces the wall. I was hoping that the control panel could be remounted 180°, but that doesn't appear to be possible. I plan to call Pentair and ask them. I'm concerned about having to brace myself against the wall and lean over the pump to activate basic features. I don't see an easy way to tell this pump to run continuously instead of using the default or custom schedule. If the panel can't be rotated on the pump, I wonder if I could remove it and mount in on the wall. If not, I might have to look for remote/automation ideas sooner rather than later.
