- Sep 3, 2018
- 1,330
- Pentair Intellichlor IC-40
I just got the K-1766. I did the test and it came to 4800 but I don't know what that means. The chart on the enclosed paper is not very helpful.
If you multiplied your number of drops x 200 and got 4800 (24 drops) then you have 4800ppm of salt in the pool. Your SWG requires somewhere between 3000 and 4000 (read the manual to be sure).I just got the K-1766. I did the test and it came to 4800 but I don't know what that means. The chart on the enclosed paper is not very helpful.
Yes, I stopped adding drops as soon as it changed from yellow.If you multiplied your number of drops x 200 and got 4800 (24 drops) then you have 4800ppm of salt in the pool. Your SWG requires somewhere between 3000 and 4000 (read the manual to be sure).
Just want to also verify that you did the test correctly. When it turns salmon color then the test is over.
They HAVE to change those instructions. Each and every one of us, our brain shuts off at ‘fill 25 ml vial’ and we don’t even see the ‘to 10ml part’.You used a 10ml sample size..right?
I think so . I'm test it again tomorrow.You used a 10ml sample size..right?
It's a new build and we did o/b. I think I'm doing it right but I'll post pics tomorrow of the test.Nikilyn,
Either you are not using the K-1766 correctly or your cell is reporting the wrong salt level..
If your actual salt level is 4800 and your cell is only reporting 3600, that is a difference of 1200 ppm.. That is way out of tolerance. The IC40 should report a salt level that is +/- 500 ppm.
I assume this is a new build with a new cell.. If so, I suggest that you call your pool builder, or Pentair, and have them come out and fix or replace the cell..
Personally, I run my actual salt level at right around 3200 ppm.. Over that level, I can start tasting it.
A difference between what your cell reports and the actual salt level is quite normal for an IC40.. but being 1200 ppm off is not close enough, and needs to be fixed.
Jim R.
You can use a 25 ml sample if you want but it will take more drops, probably close to the 50 drop threshold that makes the drop test results unreliable... AND the multiplier changes from 1 drop = 200ppm for a 10 ml sample to 1 drop = 80 ppm for a 25 ml sample. Anyway.. I agree with Jim.. I would redo the test and make sure. If you are really that far off from what the cell reports then something is awry.They HAVE to change those instructions. Each and every one of us, our brain shuts off at ‘fill 25 ml vial’ and we don’t even see the ‘to 10ml part’.
Every
Last
Time
That's exactly what I did.N,
As you get close to the right number of drops, you will see a "flash" of salmon and then it will instantly change back to yellow.. Keep slowly adding drops until it changes to salmon and does not change back.. It is a very definite change. Do not go past this definite change point.
Jim R.
The name of the color is irrelevant.. everyone will have a different perception of the color. Heck I can't tell the difference between Tangy Yellow and Daffodil Taxi. Its the color change that matters with this one. And this test has about the most definitive test off all of them.The directions say "creamy salmon" and "brick red". Those 2 colors are completely different to me so I'm going with this one.
I destest things today as well, when I channel my inner curmudgeon..I detested today
It’s a simple percentage . 25% will reduce you by 1/4 to 3600. Or we can do not so simple %s. 1/3 or 33% will bring you down to 3216. So probably somewhere in between those 2.If so, how do we know how much to drain off?
