I am adding a new pool heat pump to my existing setup. The pipe that has the flow meter is my return. The piece on the right that looks like it comes out of the heater is the elbow I need to connect to the short piece of horizontal pipe. What do you do when there isn’t enough room to add the last elbow? Is that when you have to go vertical up above both horizontal pipes to give you enough room?
