I have the quick red flash then solid green on the cell light. The salt light also flashes. I just got the pool in June and the flow switch has already been replaced. I have two questions
1. When the flow switch is bad does the I-chlor reduce the amount of chlorine that it produces?
2. My pool is a 16 X 32 rectangle and has 18,500 gal capacity. Should I ask for a larger chlorinator or should the I-chlor 30 be sufficient?
thanks in advance
thanks in advance
