Ok waiting for the test kit. I took readings with the strips again and either it’s settling from the circulation or the strips are just that off (or both)
FC = 0
Ph = 6.8
TA = 80
TH = 400
CYA = 100
Nothing added, just brushing, circulating and vacuuming. I also turned off my solar recirc so the returns are running now.
I am a little worried about doing an 80% drain. The water table by me is high, and I’m on well. I’d have to get someone to pump out and pump in.
Is it something I can manage and hope evaporation/fills/rain will take care of some of it? I know I’ll be fighting FC the entire time, but I’m not sure if that would be more expensive than pumping thirty thousand gallons of water.
FC = 0
Ph = 6.8
TA = 80
TH = 400
CYA = 100
