I am just starting out with a hot tub and since I react badly to chlorine I can’t use it. I can’t use Bromine either.
I am trying to use only iodide and peroxide. Can you help confirm if I am on the right track?
Here is my humble todo list:
I am not a chemist, but do you think I am on the right track?
- I have the tub filled with chlorine free water - done.
- Install ozone generator - done.
- Fill tub up with water
- In a 5 gallon bucket, add food grade peroxide 35% until it turns brown
=== I found somewhere that the recommended amount of 35% is ¼ cup or two ounce per 100 gallons of water intended for the tub. IslandHotTub.com - Pour those 5 gallons of peroxide water, 5 gallons into tub
- Pour potassium iodide in water to create a 2ppm solution (calculate that)
- The water should turn slightly green
- Test for bacteria levels using test strips, like this from FilterWater.com
Pool and Spa Bacteria Test 10-pack - Test level of iodide using
- Do this once in a while if water has bacteria:
- Measure amount of iodide in tub
- Add peroxide
- Add iodide
- Turn the hot tub on, cover it and let the water circulate for eight to 12 hours or overnight. Dip another test strip into the water and check for free chlorine. If the strip shows the presence of free chlorine, your hot tub is now clear of bacteria.
