So I will start with some back story to this past November when i couldn't get the pool cover to close, which turned out the shear pin needed replaced which i did. Once the shear pin was replaced i was able to open and close the pool cover with out issues. I went to open the pool cover a few days ago, and I can't get it to open. I do have power to the motor, and can see the shaft spinning all the way through to the Pool cover side, but it won't catch onto the gears.
I assumed it was the shear pin again, however this time I don't see a hole where the shear pin would go. If you click the following link it will show a video of what I'm talking about. Trouble With Hydraulic Pool Cover : swimmingpools
I then found this Pool cover problem - YouTube video on Youtube, and it shows how the gears should spin
