That looks similar to the one I ended up ordering. the Fanimation Covert.
This is the first I've ever heard of handhold tiles. Where do you put them, how are they used?And the journey continues...
22-Oct
I noticed one of our lights is busted. PB agreed to replace it.
26-Oct
Ledger stone and coping started! On this day they also realized the plumbers forgot to put in the overflow drain, so that had to get notched in on the short corner where the spa is.
27-Oct
Waterline tile started going in. No one seems to know where the handhold tiles are. The tile guys said they will cut out spots for them once they show up. Instead of tiling the bottom of the skimmer opening, they went with some cut travertine coping material. That was a surprise, was not expecting it, but I kinda like like the look. One of the corners ended up being a bit wonky, so I asked the PB if we could get that straightened out a bit more, which they did the next day.
They are kinda like rock wall grip thingies. Great for those with raised walls where you can’t just hold onto the side of the pool in the deep end. I forget the other term at the moment. Finger something or others. Lol.This is the first I've ever heard of handhold tiles. Where do you put them, how are they used?
They are a 3D tile that has a piece that sticks out a bit to allow someone to grab onto them. Here is an example (not the one we are getting though).This is the first I've ever heard of handhold tiles. Where do you put them, how are they used?
That makes sense. I wasn't thinking of the raisedThey are a 3D tile that has a piece that sticks out a bit to allow someone to grab onto them. Here is an example (not the one we are getting though).
It is a safety issue for me because of the raised back wall. I want the kids to have a spot they can grab onto while swimming in the area if they feel they need to. (The coping is too high to reach comfortably). We are getting 3 that will be spaced along the back wall.
I would not use zip ties, they can scratch up your fresh plaster, also tie on an empty water bottle to float the hose. I can’t wait to see it full of water!Dec 03
Plaster is done!
Wet Edge Signature Matrix Carribean.
Dec 04
Up for today, acid wash and start of fill. The sock and zip tie are ready to be deployed.
I used nylon string, but a rubber band should also workah ok....is a rubber band better?
