When I vac to waste, when the water level drops below the skimmer, I lose pump prime and can no longer vac. How can I keep keep vac'ing in that situation?
Seems that main drain doesn't suck at all. I noticed skimmer had one of the two holes plugged and I've been unable to unscrew that plug (hopefully not cemented shut). If that likely connects to main drain, wouldn't that allow me to continue vac'ing by pulling water from drain and keeping prime?
I've been vac'ing some to filter with help from wife who must hold the vac tube only partially over vac plate in skimmer to keep prime, but the finer particles get spat back via returns.
