How can I replace my main drain and the plumbing line to the main drain?
We discovered our main drain was retrofitted with a 1/2" diameter black poly pipe, snaked inside the original 1-1/2" line. The drain works but I can't use it fully as the pipe flow actually cavitates due to rapid decrease in pressure at the filter basket back from 1/2" to 1-1/2".
To fix this, I am assuming I have to:
- dig out the drain line, digging up to 12' deep to the deep end (and run earth dewatering due to high water table)
- possible sawcut/jackhammer the concrete surrounding the main drain
- replace plumbing
- recast concrete using doweled stainless rebar (or Simpson Heli-Ties, or similar repair products)
This is a huge project. Am I making it more complicated than it should be?
- replace plumbing
