Hi all,
Preamble:
I came to this site years ago because I do everything myself. When something expensive breaks I try to figure out how to fix it, vs get a new one. I have measured and replaced my in ground pool liner, changed my timing belt on my odyssey, and replaced my own iPhone glass. All that to say, i can do it, and for me, if I can do things nobody else is doing, I get to have the money to do things nobody else gets to do. That's a little more than you needed.
Why I am posting this:
I know my T-CELL-15 is getting on in age and, while it is producing fine, I am expecting its inevitable failure. If that happens today, its $900 + tax. I think it can be fixed
Here is what I have found:
Ebay has sellers that will take your broken T-CELL-X and fix it for you - If they can do it, I can do it.
Guy on youtube took apart his T-CELL-5 - He points out that it appears Hayward installed the Thermistor in a way that its not possible to replace it, forced obsolesce. There are manufactures out there that will pour epoxy all over the circuit board so you can't possibly repair it.
That is interesting on its own, but... If you read in the comments under that youtube link someone said this:
The most common component to fail on these units is the Thermistor that is inside the Cell that is shown in the video. The Thermistor is used to determine the water temp and salt level. If the Thermistor fails, you will more then likely get a "HOT" error on your panel. If you check the Molex connector, pins 6 and 10 connect to the blue and red wires. You can use a multimeter to check the resistance and continuity. The resistance should be around 10K ohm, +- 2K ohm depending on your temp. If you see reading that are way too high or low then your Thermistor is cooked. The easiest fix is to slice the power cord cable sheathing and expose the wires. The blue and red are the ones you need to work on. Cut the wires and solder a 10K ohm resistor between the red and blue wire that are facing the Molex connector. Give the unit a test and the error should be gone. Tape everything backup up with some electrical tape and you are done. The 10K ohm resistor has the control panel think that the water temp is 77F. Fixed my unit this way and it works perfectly. One dollar resistor and 2mins of soldering saved me $1000 for a new unit...
Ok so what's the point, what's the question?:
Questions are:
Thanks all
Preamble:
Questions are:
- Is it true that the Thermistor fails on these more often than anything?
- This solution bypasses the Thermistor, fooling the unit into thinking its 77 degrees, but the Thermistor also tests the salt ppm, right? If you use a test kit, what is the downside?
- Are there any other good solutions for fixing these units vs dropping almost $1000 on a new one?
- What other thoughts does anyone have on this?
Thanks all
