- Sep 17, 2022
- 65
- Plaster
- Hayward Aqua Rite (T-9)
My sand filter (model details in signature) does not have an air relief valve. Don’t Sand filter need an air relief valve? Any suggestions on adding one either by adding an adaptor (with relief valve in between filter and pressure gauge) or installing a pressure gauge with in-built relief valve?
Context: Although my filter’s pressure hasn’t increased more than 5 psi from the normal level (21 psi after last backwash), it has been 5 months since I backwashed. I thought I should only do it after >= 5-10 psi from normal but learnt that I should do it every few weeks especially after lot of leaves fall during fall and early spring. I will be backwashing tomorrow. My neighbor, having DE filter, also mentioned to frequently relieve air from filter to help better but I don’t have one.
