I want to set my actuator to be in pool mode regardless of the freeze mode switching from pool to spa. Before I do that and break the whole system I am trying to figure out one water flow item. In my below image there are 4 lines coming into the main pump: spa, two skimmers and the main pool drain. When the actuator is in the spa position it only pulls from the spa. When the actuator is in the pool position I assume that it pulls from everything, including the spa, otherwise the spa would be poorly circulated.
Is there any way to know for sure that this is correct? If it is not correct and I leave the actuator in the pool position that pipe would freeze.
(Ignore the frozen pond around my pool pump, it leaks water out every time the pump stops. I have a separate thread on that)
