Need help figuring out a solution to DIY fix these steps. This is an i ground vinyl liner pool with corner steps. Steps feel very solid overall. This is the corner of the step next to the short side edge on the shallow end. I have an auto pool cover and the aluminum edge (you can see it in the pic) was slipped down and rubbed on this corner causing the damage. I had a company service the cover and they sorta fixed the aluminum edge.
Pretty sure the inside is fiberglass. The outside is some type of poly. I considered just using epoxy but it wouldn’t look great.
Any thoughts?
