- Aug 25, 2011
- 611
- Vinyl
- Pentair Intellichlor IC-40
Got a picture?Other than the classic turnbuckle, is there another way to fix this gate that's sagged? You can see it's dropped maybe a half inch or so and it's enough to keep it from closing properly. And with it being metal, most of the sag kits are for wood. Suggestions?
Omg. Yeah, I didn't realize the upload didn't take. Just updated the original post.Got a picture?
Put a framing square up to check the gate and it's not square. There is a wee bit of give on the post but not a lot - it's almost plumb (the latch side is plumb). So it's a combination of both I guess. How to address either?Are you sure its the gate and not the post ? If I had to guess, 95% of sagging gates in the land are the post.
They aren't adjustable. They are truclose self closing. Here's a link to them on AmazonGot a pics of the hinges?
The link you posts says they are. You may be able to lengthen the bottom hinge to pull the top latch corner from rubbing.They aren't adjustable.
These hinges are only adjustable for tension. They do have other hinges that have multiple adjustments but those require a much larger gate gap than I have.The link you posts says they are. You may be able to lengthen the bottom hinge to pull the top latch corner from rubbing.
EASY ADJUSTMENT
TruClose hinges also offer vertical and horizontal adjustment to ensure precise alignment and reliable operation. They can be fitted to all square-posted gates.
The hinge post is leaning into the opening, slightly off plumb. The latch side post is plumb. I didn't measure the top and bottom yet, but I'd guess the top is more narrow.Let's understand what shifted.
Are both end posts plumb vertical? Put a level on all sides and see.
Is the distance at the top between the posts the same as between the bottom of the posts?
Is the opening square?
If you rehinged the gate would it fit in the opening?
I have had similar problems due to ground shifting over the years. Except in my case the gate opening widened instead of came together.
What will the eye bolts on the gate do? I need to go top hinge side to lower latch side so I'm not understanding.Eye bolts perpendicular to the fence. Bolts shown going through beam and bolted on the other side.
To pull the hinge post back, turnbuckle the top of the post to the bottom of the next post.
Yes, I did that first, tbh. It will close but the post won't stay that way.Did you try giving the hinge post a hard shove at the top with your shoulder?
It may not stay there but seeing if moving the hinge post is enough for the gate to close.
