Hi Folks:
My 40 year old gunite poll will be closed this week. I've been thinking about attempting to do this myself. Despite my pool's size, I've got a pretty simple plumbing layout. I've got 2 return jets from the filter (no valve), and only 1 skimmer basket. The main drain at the bottom of my 8' deep end is connected to the bottom of my skimmer basket and flow is directed via a float valve.
I'm pretty sure blowing out the return jets and skimmer basket should be easy using a shop vac, particularly once I drain the pool down to below the return jets.
But I have more reservation about the floor drain. Since there is no valve, I'm very concerned about how to do this properly. I believe typically my pool guys use a ton of compressed air to blow out the main drain line. Then, once the compressor is removed they "quickly" put in one of the stoppers into the port at the bottom of the skimmer and tighten quickly.
My concern is, this seems very error prone. What happens if I can't get the plug in before water has refilled the line? How can I tell if it was done properly?
Hmmm....
Suggestions?
Hmmm....
Suggestions?
